rear seat battle
Old Jul 23, 2010 | 02:10 PM
eviling's Avatar
Photobucket
Default rear seat battle
I just had an epix battle with my monte carlo in the back seat, and i really mean a battle, lasting at least 2 hours before i gave up and just bolted it down as much as i could, but i still can not get it to click in, idk if i bent some kind of plate on the bottom of the seat or what, but i can not get it to sit back down properly. its all trying to pull away at the corners, the bolts hold it pretty well but i dont wanna leave it like that, it's killing me that i feel like i physicly damaged my baby but i never did get them rear speakers out because i didnt realise i had to completly remove the rear seat. and i was unable to because my amp's are mounted to it. :'( and i coudlnt even get it unhindged at the bottm. is it bolted or hooked down on the bottom or what? i cant figure it out.
Old Jul 23, 2010 | 03:18 PM
what generation is it?
if 6th:
http://www.youtube.com/watch?v=sjtmpUmHdlA
i made that write up, just follow that, you dont need to take the seat out
Old Jul 23, 2010 | 03:34 PM
eviling's Avatar
Photobucket
yeah i figuire all that out, but the problem is i cant get the damn seat back down agaisnt the panel properly.
Old Jul 23, 2010 | 03:36 PM
on the sides? i guess i dont really understand what you mean.
Old Jul 23, 2010 | 04:10 PM
eviling's Avatar
Photobucket
well when you take those 4 bolts off, thats to take the rear part of the rear seat out. i tried pulling it out, but had no luck, but when i went to put it back up agsinsdt the back, it just kept flexing, i bolted it down, but it still flexed on the corners. i dont know whats bent, there must be a bracket on the bottom i bent, i dont know, i cant get the damn thing off to figuire it out. it must be bolted on the bottom under that little round bar thaqt goes across the middle between the the two peices. let me know what ya think. for now i'm done, i just got back inside, i took it al back appart and managed to get the rear speakers out so that i could port the sub into the cabin, whitch is what i was aiming for from the get. and i got it and it sounds very good, just that damn seat isnt sitting properly. i must of bent something.
Old Jul 23, 2010 | 04:26 PM
the whole thing shouldnt come down, it should just pull forward, the black center pieces and the two side parts will only move so far before they bend, the only way for those to move is removing the whole seat, so you should try to just remove the whole thing to see if something is bent or see if something isnt aligned right, did you say you didnt remove it comepletely? because then it is probably just bent from you trying to force it, should be able to bend it back to somewhat normal.
Old Jul 23, 2010 | 04:29 PM
Blazed SS's Avatar
IT HERTZ
i know this is non related but i love that sig pic man !!!!!!!!
Oct 29, 2014 04:00 AM
BeachBumMike
Oct 19, 2013 05:31 AM
Oct 16, 2012 09:32 AM
rj
Dec 20, 2006 01:14 PM
