6th Gen ('00-'05): Rear Defroger Breaker, Curerent
Old Dec 20, 2015 | 09:35 PM
Bob Lasko's Avatar
Default Rear Defroger Breaker, Curerent
Have a 2003 Monte Carlo SS and the rear defogger is inop. tested the circuit and found out after removing the fuse box on the right side, that there is no current getting to the breaker for the defogger. does any know or have a diagram of were the breaker gets it power from.
Thanks,
Bob
Old Dec 20, 2015 | 10:53 PM
I believe there is also a fuse for the rear defroster. Have you checked to ensure the fuse is functional and the correct size?
FYI - You double posted this same exact question in another thread in our tech info section. I removed those because this is the best place for that question (it's own thread) and it's also too much for members to help you in multiple threads.
Old Dec 22, 2015 | 07:51 PM
plumbob's Avatar
Hi Bob.
Here's the Schematic:
My bet is your problem is with the defogger relay located in the fuse box on the passenger side that you removed.
You might also have poor AM radio reception, and no power to heated mirrors (If you have them).
Hope this helps, keep us posted.
Old Dec 22, 2015 | 08:38 PM
Bob Lasko's Avatar
Originally Posted by plumbob
Hi Bob.
Attachment 17021
The radio reception is good am and fm. have not tested the mirrors yet. there is no current getting to the breaker so I do not think the mirrors are working. this schematic shows a fusible link that I got to check.
will let you know.
bob
Old Dec 22, 2015 | 09:17 PM
plumbob's Avatar
The AM and FM antennas are separate. The defogger grid actually is the AM antenna. You may still have good reception on AM if the signal is strong enough, but it would be better on week stations if the circuit was complete.
If I'm reading the schematic correctly, you would have no BCM if that fusible link were bad.
