Opinion Needed: Wheel Bearing Replacement! advice needed!
Old Dec 9, 2015 | 03:49 PM
Quentin Soules's Avatar
Default Wheel Bearing Replacement! advice needed!
Hey! New to the site and need guidance with the replacement of my front driver side wheel bearing. Could someone link me a hub assembly that will fit my 2001 LS 3.4V? Thanks!
Old Dec 9, 2015 | 05:12 PM
owens91's Avatar
Old Dec 9, 2015 | 05:13 PM
owens91's Avatar
you might wanna go to autozone and rent a hob puller alot easier it makes things
Old Dec 18, 2015 | 05:49 AM
montedd's Avatar
01 should be similar to my 07
I just changed a couple both front and back
Shouldn't need any pullers basic tools all that is needed
YouTube is your friend
Rock Auto.Com is also your friend for good prices
Should take maybe 2 hours tops to change one side
Old Dec 18, 2015 | 06:12 AM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
I just changed a lf hub on my Monte also. As mentioned at least for me I didn't require any special tools. About the only thing you may need that isn't common in most home tool boxes is an axle nut socket and torque wrench, and a 1/2 in drive ratchet or breaker bar.
Also as stated YouTube is your friend if in doubt.
I know there are hubs out there for like $25 , but I wouldn't put those things on a bicycle.
I went for an ac delco . One thing I would mention is pay close attention to the hub bolts themselves. I'm referring to the 3 that hold the hub to the spindle. If not careful they are easy to round the heads off.
Not a difficult project by any means. Take your time and shouldn't take more than hour or 2 max
Old Dec 22, 2015 | 05:47 PM
owens91's Avatar
i got a timken hub, i think they were 100 bucks
Old Dec 22, 2015 | 07:03 PM
KCFITZ78's Avatar
I went through Rockauto and went with Moog as they carry a 3 year warranty. Rockauto caries Moog priced at $93.79 for either abs or non- abs
Link ---> RockAuto Parts Catalog
Old Dec 23, 2015 | 05:03 AM
fatfig's Avatar
asy job, just need time...youtube has great videos on hub replacement
