Rear Defog Just Up and Quit Working
Old Mar 14, 2015 | 07:49 PM
child_of_fire's Avatar
i need the location of that silver 30amp breaker listed as rear defogger on passenger side dash panel....behind fuse block there are two
Old Mar 14, 2015 | 08:04 PM
Dave-
I attached a pdf link above of the lower fuse block in the engine bay on passenger side.
Should be second fuse from left.
Old Mar 14, 2015 | 08:15 PM
yes i saw that. thank you. but theres one directly behind the glove box, no?
Old Mar 14, 2015 | 08:18 PM
rtip3 is a 60 that appears to be good.
Old Mar 14, 2015 | 08:39 PM
There is a fuse block on the passenger side next to the glove box when you open the door.
Attached is the diagram for that one that has rear defogger relay and circuit breaker
File Type: pdf
Old Mar 14, 2015 | 09:05 PM
yes, when i take off the glove box i see a 30 amp breaker in the upper right (metallic fuse looking thing)...but i dont see another one. so i was asking for clarification whether i was looking at the seat breaker or in fact the degogger breaker.
Old Mar 14, 2015 | 09:06 PM
as you can see the diagram is unclear...they are referred to as "inside." so we are talking about the back of that fuse panel from my research.
Old Mar 14, 2015 | 09:23 PM
it appears that it is the back of the fuse panel
Old Mar 15, 2015 | 09:02 AM
I had to look at the pics I put in page one of this thread (as I honestly did not recall):
https://montecarloforum.com/forum/fw...breaker-33233/
It looks like it's the bottom breaker.
I believe the circuit breaker in clear view on my pics when the fuse panel is still in the car is for the power seat controls. This is why I pulled the fuse block (it didn't take long to pull and I had unrestricted access to both breakers).
jmichael67
Feb 25, 2011 01:55 PM
USMCdevildog
Dec 17, 2010 09:05 AM
montecarlo48178
Oct 9, 2010 03:31 PM
5207234w
Feb 23, 2009 11:07 PM
Nightmare!
Oct 31, 2007 06:59 PM
