rear brake noise
Old Sep 20, 2010 | 12:43 PM
goingforgold's Avatar
Default rear brake noise
my right rear brake makes a noise like the pads are slightly rubbing the rotor. Only hear this at first start off. Sounds like swoosh swoosh. Could the pads be sticking in the slides? And if so how do I fix this?
Old Sep 20, 2010 | 02:53 PM
Hi Going4Gold, and Welcome to the Mone Carlo Family.
What year Monte Carlo do you have ?
Approximately, how many miles on your Brakes ?
Were new pads installed ? If so, by who?
Check out the below links, and please give us as much
detailed information as you can about your problem.
EnJoy the MCF & we look forward to your future posts.
Eliminating Disc Brake Noise
One way to quiet noisy pads is to make sure the pads fit tightly in the .... To reduce the risk of brake noise during pad break-in, there are aerosol "brake ...
www.aa1car.com/library/tr996.htm - Cached - Similar
Brake Service - Disc Brakes Noise on Your Car?
First of all, noisy brakes should always be inspected to make sure there isn't a problem with the braking system. If the pads have worn down to the point ...
www.trustmymechanic.com/brakenoise.html - Cached - Similar
Brake Noise - How to Diagnose Problem Brakes
how to fix brake noise problems. ... A brake pad, worn down to its backing plate, will eat grooves in the rotor. ... Select a Make. Select a Model. Zip Code ...
www.automedia.com/Brake_Noise/ccr20050701bn/1 - Cached - Similar
How to Fix Squeaky Brakes: DIY Auto - Popular Mechanics
Dec 18, 2009 ... Many brake pad compositions will make a swishing or grinding noise for the first few stops in the morning until the pads warm up and drive ...
www.popularmechanics.com/cars/how-to/maintenance/4317748 - Cached
Old Sep 20, 2010 | 09:05 PM
its a 2002 monte and I have about 10000 miles on these pads. It has just started to make this noise that's why I think it may be in the slides.
Old Sep 21, 2010 | 09:24 PM
seawolf18's Avatar
It may be the adjusters(slides) sticking. When I do brakes, I make sure they move freely and lube them with dielectric grease.
I changed the front brakes on my 1980 pickup last fall, and the sliders were seized on the calibers. I had to pound them out with a punch and hammer. Then had to clean them up with a scotch brite pad, and greased them before i put them back in.
Old Sep 22, 2010 | 10:05 AM
I've done all that twice. It's the right rear and it doesn't make the noise the complete rotation of the wheel. Could I have a warped rotor on the rear? It only makes the noise for about a 1/4 part of the rotation of the wheel.
Old Sep 22, 2010 | 11:18 AM
thumpingetocar06's Avatar
Photobucket
Monte Of The Month -- October 2010
I would have to say a warped rotor is my guess.... how long have they been on? It makes sense for the fact the back rotors are a lot thinner than the front and have a greater possability of warping. Another thing I could think of is your pad is wearing funny which would lead to be a slide not functioning right.
Old Sep 22, 2010 | 11:47 AM
rotors have about 50000 miles. The pads look good I don't see any uneven wear. It's like something is out of round because it doesn't make the noise for the complete rotation of the wheel. I've never experienced a rear rotor warping. If it was the slides wouldn't the noise continue for the complete rotation of the wheel? I know when a front rotor is warpped you get a vibration when stopping. I don't have anything but this noise.
Old Oct 11, 2010 | 11:19 AM
Well I've had the pads off six times and greased the slides. Also the the caliper slides. I still have that noise but not the entire rotation of the wheel. This noise comes and goes. Mostly after you drive a few miles you hear it more. Something is definitely rubbing part of the rotor but I can't locate the problem. Driving me crazy
iceman56607
Mar 6, 2011 03:29 PM
Harleyldraper
Sep 14, 2010 11:34 PM
rlsc98
Sep 13, 2008 04:20 PM
yiranhu
Nov 22, 2007 05:32 PM
97z34
Sep 22, 2006 10:40 PM
