6th Gen ('00-'05): REALLY stripped oil pan bolt :(
Someone changed it at one point then. GM only uses 13mm and 15mm on everything except for daewoo's, Duramax engines, and cruzes.
There have been a bunch of good ideas posted. I think I lean in, a GOOD set of vice grips for the job (as I noted earlier, I know at least 2 different styles and the one probably will not work well for this job).
The other thing, stop putting the plug on monster tight.....
And when I'm changing the oil on my 2000 or my parents' 06, I never seem to remember which is which and grab the wrong one. Never fails haha
Another thing I have had success with is using a dremel to cut a slot in the head of the bolt, then getting a really big and broad flat head, sticking it in the slot and backing the nut out - just as if it were a flat head screw.
snap on and craftsman both make tool sets for rounded bolts. personally i wouldnt heat it or hit anything aluminum with a hammer. bad things happen very quickly, and if you arent careful, you will be replacing more than what you want. most garages could get the bolt off for you and install a new one for a minimal fee, with an oil change. btw. you dont have to tighten the hell out of an oil plug.
scc24540
07-01-2007 06:34 PM
