6th Gen ('00-'05): REALLY stripped oil pan bolt :(
Old Dec 1, 2012 | 05:49 PM
bizparr's Avatar
Default REALLY stripped oil pan bolt :(
I noticed the bolt was starting to strip about 2 or 3 oil changes ago, but I kept forgetting about it and putting it off. Anyway, now I've got a problem.
After the 14mm socket stopped working, I tried vice grips. I'm a pretty strong guy, all I managed to do was round out the bolt even with them tightened as much as possible. After that, I took the truck down to the parts store and picked up a bolt remover kit. I can't even get the de-threader to work, even with the 13mm socket (14mm just floats, it's not even close).
Last oil change I did, I was in too much of a hurry and must have cranked the bolt down too hard. Now I know I can't be the only idiot in the world that has tightened down a stripped bolt too much and not been able to get it out, can anyone help me out here?
Attached a few pictures so you can see what I'm dealing with...
File Type: jpg
File Type: jpg
File Type: jpg
Old Dec 1, 2012 | 06:05 PM
DE02Carlo's Avatar
Can you get a pipe wrench on it to get more leverage? Otherwise vise grips is what I would have tried. Not sure if heating it would help.
Old Dec 1, 2012 | 06:12 PM
bizparr's Avatar
I could probably fit a smaller sized pipe wrench on there, I don't know if it'll do much good though. I wish I had a blowtorch handy..
Old Dec 1, 2012 | 06:30 PM
It looks like you rounded the head off of the drain plug
you could remove that drain plug an install a new one.
Old Dec 1, 2012 | 06:44 PM
03SSLE's Avatar
Do you have a Dremel tool? If so, grind the edges down so you can fit a 6 point socket or box end wrench on it. Heat it with a portable torch, let it cool then go at it with a 6 point socket and breaker bar. If you have to use a box end wrench slide a piece of pipe or something over the end for greater leverage.
Old Dec 1, 2012 | 07:45 PM
bizparr's Avatar
I was thinking a strong file myself, but a dremel sounds much easier on the hands. I'll have to see if I can find one to borrow.
I appreciate the responses guys, going to attack it again tomorrow morning. Hopefully I can get it out without too many bruises and foul words.
Old Dec 1, 2012 | 07:59 PM
DE02Carlo's Avatar
If you had an air hammer you could try to catch the outer edge of the large diameter part of the bolt in the direction that would loosen it. I have removed things like that in the past. Just have to be careful not to damage the oil pan.
Old Dec 1, 2012 | 08:28 PM
Enzo354's Avatar
STILL SLOW
Errrrr.... keep trying the vise-grips, but hit it with your hand or a hammer instead of a constant motion, it won't strip as easy. Almost like using it as an impact.
Old Dec 1, 2012 | 08:31 PM
aussiek2000's Avatar
Ding, ding, ding. This is how I remove them at work. I use a SHARP chisel bit on my air hammer and work the edge to loosen it up.
To the OP: The drain plug is 13mm, not 14mm. This is why you stripped it. 14mm is only on Asian imports.
Old Dec 1, 2012 | 10:27 PM
Johnboyp92's Avatar
use the vise grips a torch and pipe at the end of vise grips promise to work
