radio problem
Old Jun 1, 2010 | 07:54 PM
exmurderblah's Avatar
Default radio problem
hello all, 1st post here.
i have an 01 monte carlo ls. there is power to the radio i can change stations but there is no sound. when i open the car doors there is no chimes either.idk what the problem is. my amp?
Old Jun 2, 2010 | 12:59 AM
TheMonteMan's Avatar
i actually have a similar issue, but mine comes and goes. i havent figured out if its the factory amp over heating or a loose wire. im still under warranty though.
Old Jun 4, 2010 | 01:46 AM
lucian*91's Avatar
the amp only controlls the rear speakers though doesnt it?
Old Jun 4, 2010 | 01:44 PM
Dyonysis's Avatar
the amp controls them all. The actual radio outputs are very low voltage so all channels get amplified by the rear stock amp.
P.S> I have a factory amp from a 2000 monte i have been too meaning to list for sale if you need a new one.
Old Jun 4, 2010 | 02:19 PM
04MonteLS's Avatar
Dang, not sure what the problem is. I'd disconnect and clean the plugs on the amp and back of the deck with electrical cleaner then plug back in and see if that makes any difference.
Old Jun 4, 2010 | 02:30 PM
Yeahm sounds like a loose wire to me??
Old Jun 17, 2010 | 10:21 AM
yeyeee01's Avatar
id check to see if you are getting a voltage or a signal into the factory amp. if you are, then check if the signal is comming out of it. it could also be your radio
Old Apr 27, 2013 | 04:17 PM
dellm's Avatar
Awaiting Email Confirmation
Default 2004 monte carlo no sound
i have the same issue with my sterio i have replaced the amp replaced the radio checked all fuses and speakers checked wires to no avail
ANY HELP WOULD BE APPRICIATED !!!
Old Apr 27, 2013 | 06:19 PM
ive had my radio replaced 2 times. problem goes away and comes back every couple of years.
guysnydr
Sep 18, 2013 07:43 PM
dustybird3
Apr 8, 2011 10:10 PM
ralphtrent
FWD Tech Guides '95-'07
Nov 28, 2010 04:35 AM
montecarlomichael
13
Dec 19, 2009 03:10 PM
ericbaker
Nov 27, 2009 04:24 PM
