Radiator leaking BAD, need help!
Old Jan 14, 2014 | 09:34 PM
Knightwolf702's Avatar
Default Radiator leaking BAD, need help!
Radiator is leaking from the bottom, looks like bushings or something. There are two one on each side, the driver side is leaking. How would I replace them?
Old Jan 14, 2014 | 10:14 PM
l67ss's Avatar
If its not a hose or the petcock, you need a new radiator.
Old Jan 14, 2014 | 10:19 PM
If you are talking about what I think you are talking about, bushings don't leak. Those are to control vibration between the body of the car and the radiator.
Best best, go use the loan-a-tool from the parts store, get a Radiator Pressure Tester. Car off, pressurize it and then look/listen for the leak. Could be a hose, could be a radiator.
Old Jan 17, 2014 | 07:46 PM
Found out what it was, plastic is cracked on the side. Drains down to the drain plug to the bushings. Thatz why I was so confused
Old Jan 17, 2014 | 07:51 PM
l67ss's Avatar
B a good time to swap in an lq1 radiator
TMoney
Apr 9, 2014 09:32 AM
robz
Nov 14, 2013 10:53 PM
Krazys02
Nov 10, 2013 11:22 AM
BigPana
27
Jun 24, 2011 11:37 AM
rgant_19
18
Dec 28, 2009 08:49 PM
