Radiator Fan
Old 06-05-2010 | 01:24 AM
Sliver's Avatar
Default Radiator Fan
I was just curious to know how much of a PIA it is to change a radiator fan motor. With the warm temps now, my car will heat up and the fans will kick on and I hear a terrible noise coming from the fans, kind of sounds like the noise a camel would make if it was being skinned alive. Kinda of embarassing to be sitting in traffic and your car starts to howl like a banshee and that cute girl next to you chuckles and rolls up her windows!
Old 06-05-2010 | 07:53 AM
Hi `Bob,
I've never had to change a fan, but hopefully one of our expert tech member's will make a post & let you know what
problems they may have encountered.
Until then you can check out the below links...Hope they
give you some insight & cost of replacement...
Check back later to see what member's post on your Thread Question....Wish you a E.Z. repair : )
2001 Chevrolet Monte Carlo Consumer Review Page 2
Jun 6, 2007 ... 2001 Chevrolet Monte Carlo SS 2dr Coupe (3.8L 6cyl 4A). Review .... I had to replace the radiator fan unit this past year. ...
www.edmunds.com/chevrolet/montecarlo/2001/consumerreview.2...html - Cached - Similar
01 2001 Chevrolet Monte Carlo Auxiliary Fan Assembly - Cooling ...
2001 Chevrolet Monte Carlo, Rad & A/C Fan Assy w/o HD ... Notes: Dorman Engine Cooling Fan Assembly - "Incl. Shroud, Motor & Blade". Availability: In Stock ...
www.partsgeek.com/.../2001/chevrolet/monte_carlo/.../auxiliary_fan_assembly.html - Cached
2001 CHEVROLET MONTE CARLO SS 3.8L 231 cubic inch V6 FI (K) OHV ...
Please check notes in each part listing to ensure the Radiator Fan Motor Connector is correct for your 2001 CHEVROLET MONTE CARLO SS with a 3.8L 231 OHV ...
www.rockauto.com/.../x,carcode,1368402,parttype,2556,d,2001_CHEVROLET_MONTE_CARLO_SS_3.8L_231_cubic_inch_V6_F... - Cached
CHEVROLET MONTE CARLO Radiator Fan Kit from Best Value Auto Parts
Get FREE shipping when you buy more CHEVROLET MONTE CARLO Radiator Fan Kit and ... When it comes the time to replace your CHEVROLET MONTE CARLO Radiator Fan Kit ... Engine Cooling Fan Shroud part for 2000-2001 CHEVROLET MONTE CARLO with ...
www.bestvalueautoparts.com/Replacement.../CHEVROLET/MONTE_CARLO/A_C_Aux_Ele_Cool_Fan_Kit.html - Cached
2001 Chevrolet Monte Carlo : RepairPal
Information on 2001 Chevrolet Monte Carlo. Extended life coolant may become ... what no change,then said it had to be fan relays,replaced all three, ...
repairpal.com/chevrolet-monte_carlo-2001 - Cached - Similar
WikiAnswers - Chevy Monte Carlo Questions including "How do you ...
May 19, 2010 ... How do you change the thermostat in a 2001 Chevy Monte Carlo LS? ... Bad radiator fan motor; bad radiator fan relay; clogged radiator; ...
wiki.answers.com › ... › American CarsChevrolet - Cached - Similar
Old 06-07-2010 | 12:26 AM
Sliver's Avatar
Thanks Kidspace for the links, there is some good info there! Thanks Again!!
Old 06-08-2010 | 11:21 PM
Justin Knight's Avatar
The fans are all one piece and the motors alone cannot be changed, find a working pair of fans at a auto recycler. Probably get one for $75-$150 depending on the yard. And to change it there are 2 10mm bolts that hold the top of it to the rad then the trans cooler lines clip into a holder at the bottom. If you remove the the stock air box and battery it's way easier to remove but can be removed with a little force and no broken parts without. The upper trans cooler line if it comes out of the rad easy makes the job as easy as a $5 hooker.
gmartinez93
05-11-2015 11:45 PM
NYGiantsfan
08-15-2013 08:43 PM
jhbasse
01-15-2013 07:39 PM
01SSMonte
02-27-2010 02:33 AM
wildchild00
01-22-2007 06:37 PM
