TB Screen Removal
Old Feb 9, 2007 | 08:19 PM
mentiroso's Avatar
Default TB Screen Removal
I did the TB screen removal on my 04 Intimidator and also on my dads 00 Bonneville SSEI. On my car it took roughly 10 minutes which 8 minutes of that was looking for something with tips small enough to remove the c-clip. Also people have suggested using a flathead to pry the screen out which didnt work for me. What worked for me was using a screw (one of the ones I used to remove the c-clip) and I hand screwed it into the screen about 1". I then pulled on it and the screen popped right out. Much easier and basically makes a little handle for the screen. On the Bonneville SSEI, it took me 3 minutes total time from start to finish, using the same technique with the screw. I am no mechanic so just for those who have not done this in fear of messing something up, it is easy to do and quick. Took one flat head screwdriver, 2 small screws (like license plate screws) and thats it.
Just thought I would post it to let some of you guys know how easy it is AND about the using a screw to remove the screen instead of trying to pry it out with a flathead screwdriver.
Old Feb 11, 2007 | 02:16 AM
White05LT's Avatar
Default RE: TB Screen Removal
Hey dude, good tip. I used a set of pliers that were specifically for removing those clips, and then used my trusty Smith & Wesson pocket knife.
Old Jun 1, 2010 | 06:15 PM
blackbeauty89's Avatar
why would you want to remove that screen?
Old Jun 1, 2010 | 06:24 PM
I understand why you'd want to, but I've never been convinced this helps. I'm glad my MAF gets accurate readings.
Old Jun 2, 2010 | 08:38 AM
Why would you ask after the post was done 3 years and 2 months ago?
Old Jun 2, 2010 | 05:51 PM
well i could have made a seperate thread about the exact same thing!
Old Jun 2, 2010 | 06:33 PM
Nah, that's the best! I love thread resurrections! Its like making friends with people who don't know it and never will. Are the OP still on the board even?
Old Jun 3, 2010 | 08:46 AM
So do you want to just know?
A lot of people think the screen is an obstruction of flow so they want to remove it, less obstructions = more air = more power.
But the screen helps straighten the air for the MAF sensor and give accurate readings, which is much better than the 1% of air increase haha
Old Jun 3, 2010 | 09:19 AM
MAMONTE's Avatar
Totally and 100% correct!
Old Jun 3, 2010 | 11:57 AM
LW57912's Avatar
So with that said...I noticed 2 big dents in my screen last night when I took off the air intake tubing. Should I replace the screen?
