Problems with Monte
Old Feb 12, 2010 | 04:44 PM
Patches O'Hoolihan's Avatar
Default Problems with Monte
I have 2000 Monte Carlo SS with the 3.8 Series 2. So far it's only happend 3 or so times now and it just started doing it this week. To my knowledge it was at the shifting points when it would shift up then shift down but then shift up finally, it would do it at 30 or so and about 60. Then ocassionally during idle it would be at about 1,000 rpm then it would drop to under that and then shoot up to 2,500 rpm and then back to regular. I added tranny fluid because it was a bit low, the intake problem has already been taken care of. I don't know whats wrong with it. I thought maybe it was the MAF sensor since it would do the weird shifting when I was moving so yeah. Any help or ideas would be greatly appreciated. Thanks, Patrick.
Old Feb 15, 2010 | 10:19 AM
monte07's Avatar
do you know what color is the tranny fluid is it the comon red or a little dirty? also when was the last time was the plugs have been changed the wiered how it sounds before i did my plugs it was doing the same thing
Old Feb 15, 2010 | 10:33 AM
It could be the catalytic converter starting to clog up on you.
But a good read on transmissions:
tripleedgeperformance.com
Old Feb 15, 2010 | 02:39 PM
Figured it out, I finally got a Check Engine light and sure enough it was the MAF sensor. Bought one from a local guy for 12 bucks. Shes running like a top again, but I'm still going to replace plugs and wires, and tranny fluid is still good but I also plan on changing it within the next few weeks. Thanks for the help.
Old Feb 15, 2010 | 10:44 PM
Ixion's Avatar
Well, that answers the question I had at the end of the other thread.
Pavix
Feb 14, 2007 05:10 PM
Raybobk
Jun 12, 2006 11:17 PM
Monte1997
Mar 11, 2006 01:59 AM
bpick32
Jan 20, 2006 08:07 PM
Mirrorimij
Dec 16, 2005 03:03 PM
