Problem with '05 cruise control
Old Sep 22, 2013 | 11:48 AM
saigashooter's Avatar
Default Problem with '05 cruise control
So the cruise in the monte has gone out, and i'm hoping someone can give me a little guidance on where to start looking.
I verified all the fuses are good, and then proceeded to check the electrical cables for breaks and corrosion and they look good.
The cable from the throttle to the cruise module module doesn't really seem to be attached on the throttle side. It goes into a small plastic cam, but it just slides through it. Should this be connected more like the actual throttle cable that uses a post to hold the cable to the throttle?
I plan on looking at the vehicle speed sensor later today to see if it is in good shape or not.
On a related note, does anyone know if it is possible to take the slack out of the throttle cable? I can pull on the cable and hear the pedal in the car flop around.
trich3838
Sep 27, 2012 08:14 PM
ginniet
Jun 20, 2011 06:15 PM
dogmanx
Nov 17, 2006 03:25 PM
Seanzy
Jun 1, 2006 08:32 PM
montejass
Mar 22, 2005 04:04 PM
