Cruise Control on 2000 LS
Old Nov 17, 2006 | 03:12 AM
dogmanx's Avatar
Default Cruise Control on 2000 LS
My Cruise control does not engage when turned on. Has anyone else had this problem? Easy fix?
Old Nov 17, 2006 | 05:34 AM
z34phoenix's Avatar
Default RE: Cruise Control on 2000 LS
first check fuses, make sure you are activating it correctly... you have to turn it on and then press set. if it is on turn it off and then back on. (yeah you might know that but just making sure)
-fuses
-make sure there are two cables atached to the Throtle body... they will look like two throtle cables one is your gas pedel and the other is the cruse. follow the cruse to the box in the engine bay the other cable will run inside the car thru the fire wall... make sure the connectors are hooked up to the cruse control box.
Old Nov 17, 2006 | 03:25 PM
dogmanx's Avatar
What if everything is connected? What could be the problem??
heavy chevy
Sep 25, 2010 04:54 AM
RickCoMatic
Jan 3, 2008 08:50 PM
RickCoMatic
Dec 16, 2007 02:22 PM
Seanzy
Jun 1, 2006 08:32 PM
montejass
Mar 22, 2005 04:04 PM
