5th Gen ('95-'99): Pressure for A/C refrigerant
Hi all,
I'm trying to find the low-side/high-side pressure for a 1996 Monte Carlo 3.4L. If possible by temperature. I've looked all over the web with no luck and the Chilton manual is a bust. If anyone happens to know I would be much appreciative. Btw, I'm universal certified if that matters to you.
Best Regards,
Scott
Best Regards,
Scott
HI Scott:
Welcome to the forum...
Lots of Great Info and members here! As a 5th Gen owner myself... I believe the High side pressure should read 4.9 lbs... at least that's what mine was the last time I had it recharged. I honestly do not know what the LO side should read.. as we completely pumped my system out and started from scratch when we refilled the system. Now.. It will freeze you out...lol
Pls join the conversation in the members daily blog! Come say hi or just see what other members are up to each day!
Thanks for joining the MCF Family!
Don't forget to post some pics of your Monte Carlo when your able!
Keep us posted on what you find out so that other members may need the same info as well!
Hope this helps...
As I am sure other members will chime in with more info/ideas to help you out!
Hope this helps...
Randy Biron
Jul 14, 2012 08:07 PM
mattilus2121
Apr 16, 2009 03:52 PM
mattilus2121
Mar 31, 2009 02:45 PM
