Power window problem
Did a search but no luck. My passenger power window quit working. Did the obvious and tried both switches. Figured the motor was toast as it had been getting slower. Pulled the panel, removed the assy and just to make sure I tested it with my jump box and of course it works.
Soooo, back out with my volt meter. No voltage at the passenger switch and none to the plug to the motor using either switch.
Drivers side works fine. 2001 model year.
jeffsmonte
Nov 21, 2022 07:34 AM
7th Gen ('06-'07): Power Steering Power Problem
TomF106SS
Oct 6, 2014 10:13 AM
TrapShooter8
Jun 3, 2007 08:31 PM
