POWER WINDOW
RE: POWER WINDOW
i heard you talking about me again Monte LOL
they are easy as hell the biggest thing is when you pull the door panel off be careful to make sure the window is down .
Then just take the panel off the door but don't try to go to far with it as the wiring harness in there is not real long.
the window switch will hang you up if you try to.
the plugs are in my opinion put in back wards so they are kind of a pain in the **** to get to . but take your time and a small screw driver and push in on the release on them then pull them straight off.
Also the one for the door locks will stay on the Handel pull. I leave min on the door just undo the screws so it will fall off the door and take it off the Handel. then turn it flat and it will fit threw the same hole it covers when your taking off the panel.
to get the switch it's self off the door panel support the panel its self on a bench or something solid. turn it upside down. you will see a place where you can get ahold of it with your thumb. on the front side . do the back side first take your small screw driver and stick it in there so you don't break the tab off but your releasing it from the panel then use your thumb to pull it out.
by doing the back one first it should snap out of there easier. (mine do anyway) other wise you will get the one side out the other one wont release for ya and your fight it for half the day . (been there done that NO FUN)
this all sounds harder then it really is. it is actually about a 20Min job taking your time to bereal careful not to break the plastic clips that hold it all to gather.
jeffsmonte
11-21-2022 07:34 AM
Jester_20
08-24-2014 02:29 PM
02 Earnhardt Monte Carlo SS
11-10-2011 10:13 AM
TrapShooter8
06-03-2007 08:31 PM
