Power seat broken
Old Oct 7, 2007 | 04:09 PM
Gr4v3_7's Avatar
Default Power seat broken
My drivers side power seat in my 2000 SS will not move forward or back. It will move up and down, bot not front or back. I was thinking it might be the motor, but it still moves up and down, so I dont know if it is a seperate motor, or maybe a wire or something? Anyone got any ideas?
Old Oct 7, 2007 | 04:18 PM
emt1134's Avatar
Default RE: Power seat broken
The horizontal (back and forward) and vertical (up and down) work off of different motors. First you need to check if there is anything under your seat that is not allowing movement (check for objects in the track, big bottles, etc..). If that reveals nothing, you must check to see if you are getting power to the motor. Here are the terminal descriptions:
Driver Seat Adjuster Switch
Connector Part Information
[align=left]
12064998 [/align][align=left]
8-Way F Metric-Pack 280 Series (BLK) [/align]
Pin
Wire Color
Circuit No.
Function
A
LT BLU
283
Power Seat Motor Feed-Driver Rear Height-DOWN
B
YEL
282
Power Seat Motor Feed-Driver Rear Height-UP
C
DK BLU
287
Power Seat Motor Feed-Driver -Front Vertical-DOWN
D
DK GRN
286
Power Seat Motor FDeed-driver-Front Vertical-UP
E
BLK
1850
Ground
F
TAN
285
Power Seat Motor Feed-Driver Seat FORWARD
G
LT GRN
284
Power Seat Motor Feed-Driver Seat BACKWARD
H
ORN
2340
Fuse Output-BATTERY
Seat Adjuster-Horizontal Actuator Motor, C1
[align=left]
12052110 [/align][align=left]
2-Way F Metric-Pack 480 Series (NAT) [/align]
Pin
Wire Color
Circuit No.
Function
A
TAN
285
Power Seat Motor Feed-Horizontal Forward
B
LT GRN
284
Power Seat Motor Feed-Horizontal Aft
Gib
Feb 2, 2014 08:35 AM
BenTheFox150
Jul 26, 2011 12:32 PM
tbmaniacal
Nov 29, 2010 02:09 AM
powerliftin
Jul 24, 2010 04:46 PM
fastback4
Dec 21, 2008 06:39 PM
