6th Gen ('00-'05): Possessed Monte
Old Aug 6, 2012 | 01:00 PM
MonteMan92's Avatar
Default Possessed Monte
Ok...I am having a ton of issues with my 2002 SS. It's got 106,000 miles and just started doing some strange things. When I start it up the Cruise light lights up in the dash and the A/C compressor clicks on and off even though the switch is off. Also the Driver info thing by the sunroof won't turn on. This is all solved by turning the fan motor switch from 0 to a speed setting. As soon as I do that the cruise light goes off and the DIC comes on. Also my keyfob hardly ever works anymore and when it does the horn does not do it's usual honk but very weird fast and short honks. I have already replaced the keyfob battery so I am pretty sure it isn't that. I have had a couple strange electrical issues come and go but nothing like this. The car had a remote start box under the dash when I bought it but I took it out because I heard they can cause issues and I didn't have the remote for it anyway. The car has some codes stored. One is for the cruise circuit and it has a couple communication malfunction codes. Help! Any input is appreciated. The dealer said they think it could be a wiring issue but I don't want to pay them for hours of wire tracing if I don't have to.
Old Aug 6, 2012 | 01:20 PM
First thing I would do is check all fuses.
If you're good with the fuses, I would check ALL the wiring by where the remote start box was. If that turns out good then the fun begins.
I would start checking all wiring by the DIC (driver information center), HVAC (fan speeds), cluster and under the dash.
It sounds like some wires may be crossed.
You could also check the relays, possibly an A/C relay?
If you haven't taken the dash off before, here's my video on how to do it:
Any other questions, feel free to ask, maybe someone else will have an idea as to what may be wrong also, but with wiring it could be a lot of different things.
Good Luck!
Old Aug 9, 2012 | 05:53 PM
MonteMan92's Avatar
How to Remove a 00-05 Monte Carlo Dash-red04montels-HD - YouTube
Good Luck!
Thank you for the reply! I looked at fuses and wires and all looks ok. I went to the dealer and discussed it with the service manager and the first thing he said was it sounds like the BCM. I have an appointment for them to look at it on monday. They said the BCM is $245 and to put it in is an hours labor. They also said I should get it diagnosed first and that is another $100. I just paid them $100 for them to say the cruise module is going bad and I don't think that is causing all of these issues. So I am kind of mad I have to pay two diagnostic fees for the same problem. Anyway...thank you again.
P.S. That video was extremely helpful!
Old Aug 13, 2012 | 06:37 PM
MonteMan92's Avatar
Well I took her to the dealer. She even has them stumped. They said they had three techs look at her and none of them has an idea of what is wrong. They are keeping her overnight. Not sure what to think at this point.
Old Aug 17, 2012 | 10:00 PM
MonteMan92's Avatar
Ok.....dealer said it is the ignition switch. I ordered a new one and I am replacing it tomorrow. I really hope this fixes it!
Old Aug 18, 2012 | 12:32 AM
blackmonte02's Avatar
I have heard some of those same problems with some guys around here and they just have a autobody place but a "mod" or whatever instead of replacing the whole ignition switch
Old Aug 20, 2012 | 11:24 AM
MonteMan92's Avatar
So I put a new ignition switch in and so far so good!! No more issues!
iMuf
Jul 20, 2013 04:30 PM
Michaelsmonte
Jun 26, 2013 01:23 AM
Adam 03 SS
14
Nov 21, 2012 10:50 PM
ABLOND
Feb 21, 2012 07:09 AM
RickCoMatic
Jan 3, 2008 08:50 PM
