po412 & p1811
Old 02-07-2011 | 08:53 PM
Redline29's Avatar
Default po412 & p1811
i have a 2000 monte carlo ss and i got these codes when i did a obd test.
"po412 Air switching valve a problem"
"p1811 Maximum adapt and long shift"
any ideas what these codes mean and how i can fix the problem? thanks for the help.
Old 02-08-2011 | 02:47 AM
nitehawkjcb's Avatar
P0412 indicates an issue with your AIR pump/solenoid. I believe the solenoid is under the coils, but I'm not 100% on that.
The P1811 means the transmission is struggling. One of two things is your issue - a solenoid in the transmission (pressure control solenoid most likely) has gone bad, or the transmission is on it's last leg...
Old 02-08-2011 | 06:50 AM
Redline29's Avatar
transmission actually feels fine it doesn't shift hard at all so im hoping its just a solenoid...unless it doesnt matter if it feels like its not shifting hard. every shift is still very smooth. also the engine check light comes on once in a long while, then disappears when i dont drive the car for a day if that info is any help.
Old 01-26-2012 | 10:28 PM
Redline29's Avatar
car doesn't shift into overdrive on the freeway. Does that info help narrow down the possible problem in the transmission?
Old 01-26-2012 | 11:29 PM
Could be a solenoid or the torque converter going bad
Tzarm
06-27-2016 09:21 PM
jamie_marie
03-01-2013 09:47 PM
Dubstepticon
06-28-2012 10:51 PM
SuperSexie02
08-10-2011 11:51 PM
Nightmagic11801
01-27-2011 07:58 AM
