po412 & p1811
Old Feb 7, 2011 | 07:53 PM
Redline29's Avatar
Default po412 & p1811
i have a 2000 monte carlo ss and i got these codes when i did a obd test.
"po412 Air switching valve a problem"
"p1811 Maximum adapt and long shift"
any ideas what these codes mean and how i can fix the problem? thanks for the help.
Old Feb 8, 2011 | 01:47 AM
nitehawkjcb's Avatar
P0412 indicates an issue with your AIR pump/solenoid. I believe the solenoid is under the coils, but I'm not 100% on that.
The P1811 means the transmission is struggling. One of two things is your issue - a solenoid in the transmission (pressure control solenoid most likely) has gone bad, or the transmission is on it's last leg...
Old Feb 8, 2011 | 05:50 AM
Redline29's Avatar
transmission actually feels fine it doesn't shift hard at all so im hoping its just a solenoid...unless it doesnt matter if it feels like its not shifting hard. every shift is still very smooth. also the engine check light comes on once in a long while, then disappears when i dont drive the car for a day if that info is any help.
Old Jan 26, 2012 | 09:28 PM
Redline29's Avatar
car doesn't shift into overdrive on the freeway. Does that info help narrow down the possible problem in the transmission?
Old Jan 26, 2012 | 10:29 PM
Could be a solenoid or the torque converter going bad
Tzarm
Jun 27, 2016 08:21 PM
jamie_marie
Mar 1, 2013 08:47 PM
Dubstepticon
Jun 28, 2012 09:51 PM
SuperSexie02
Aug 10, 2011 10:51 PM
Nightmagic11801
Jan 27, 2011 06:58 AM
