Please help!!!!
my M.C. has a "1st generation" window switch which needs replacing. the only ones avail. now are 2nd gen. which DO NOT fit. i know there is a way to re-wire the switch so that the 2nd gen. will fit, but i need a wiring diagram for the switch--driver's side master switch. I've searched since July 2018, and still haven't found the switch, or an EXACT wiring diagram for a 1995 Z34.
I'd apreciate any help with this very much! |
Originally Posted by dd850
(Post 716233)
I'd apreciate any help with this very much! Here is a link to ebay buy the Factory service manual for this info. Also you may need to find a U-pull it salvage yard and get the switch from a Lumina or a Monte Carlo. It could be a simple as changing the connector plug. You could get that wire section with the plug from the salvage car and then wire it up to your car.? https://www.ebay.com/sch/i.html?_fro...+1995&_sacat=0 |
