Piston rod?
Old 04-10-2013, 04:11 PM
Harlan2012's Avatar
Default Piston rod?
Once it starts making noise is that it? New motor time?
Old 04-10-2013, 04:18 PM
owens91's Avatar
unless you wanna do a rebuild
Old 04-10-2013, 08:24 PM
turbo monte's Avatar
are you sure its a rod? if it is its time for a complete rebuild or a engine swap.
Old 04-12-2013, 03:08 PM
Harlan2012's Avatar
Whats the difference between a 01 ss 3.8 and 02 ss 3.8 if any? Jus askn cause i plan on swappin motors.
Old 04-12-2013, 07:47 PM
I don't think there is a difference between the 2, I don't think the 3800 even went under any changes until the series 3 was designed.
Old 04-13-2013, 03:19 PM
that i know of there is no differences but i could be wrong....
Old 04-13-2013, 09:47 PM
PacerSS's Avatar
No difference. You can use all the way up to an 03. Actually you can use anything below an 05 in the pontiacs or buicks that came with the 3800 non supercharged that is. Unless you plan on changing the PCM too.
Old 04-14-2013, 10:21 AM
Harlan2012's Avatar
So if i swap tha 3800 from the 01 ss into my 02 ss i wont have to worry about PCM issues?
Old 04-14-2013, 06:07 PM
PacerSS's Avatar
Nope not at all. Should transfer over perfectly.
Old 04-14-2013, 08:48 PM
Harlan2012's Avatar
http://www.justanswer.com/pontiac/2u...percharge.html
Will that procedure be basically the same for a monte?
Quick Reply: Piston rod?
