Pesky Turn Signals
Old Feb 18, 2008 | 10:58 AM
Maroon_MonteSS's Avatar
Default Pesky Turn Signals
Hi All,
New to the forum but, I've read many of the postings looking for this answer. Reliving my childhood (had a 77 Monte), and just bought a used 02 Monte SS, 3.8. When I bought the car the turn signals worked, now they don't. Checked the fuses driver and passenger side and under hood, all seem fine. Went to the next step the flasher however, I can't seem to find it. Found no mention in the owner's manual and autozone said it should beon the driver side beneath the steering column. I can't seem to find it. Am I blind? Any help would be appreciated.
Old Feb 18, 2008 | 08:05 PM
bowtietech's Avatar
Default RE: Pesky Turn Signals
The turn signal flasher is incorporated into the hazard light switch.If you want to replace the flasheryou will need to replace the hazard switch. On 2002 Monte Carlo's,the hazard switch is the most common cause of inoperative turn signals. Sometimes just turning the hazard lights on & off several times will restore turn signal operation,but that is not the fix. You will need a new hazard switch.
Old Feb 18, 2008 | 08:57 PM
v8_Killa's Avatar
yea i'm having the same problem almost failed a state inspection because of this any idea on how much this to fix?
monteriderLS
Apr 1, 2013 08:57 AM
01whitess
Feb 18, 2013 08:55 PM
MELISSA
Aug 14, 2007 03:29 PM
InTheIROC
Jan 11, 2006 10:55 PM
