Passenger side headlight dim no brights.
Old Aug 16, 2018 | 09:14 AM
tjk's Avatar
tjk
Default Passenger side headlight dim no brights.
2002 Monte SS. It had been wrecked. Was repaired. Trying to get the headlights to work driver side works fine. Passenger side comes on but is very dim. Turn on brights. Nothing. Tried swapping headlight assemblies and same thing. So is it a ground? If so where does the ground from the passenger side go? I’m not real educated on newer auto wiring. Thanks in advance for any ideas. I’m all ears (or eyes in this case)
Old Aug 16, 2018 | 12:04 PM
Smile
When in doubt go to youtube and see what there is. This is a link for google search, and onto youtube so you can pick a few that may assist in solving the issue. Most likely you have a ground issue and it maybe loose or the connector is dirty but finding it will take a test tool. Check this link. https://www.google.com/search?client...10.bHGhasvpdjE
Randy Randolph
Dec 8, 2017 09:50 AM
New2MonteNY
Jan 2, 2014 11:14 AM
lougreen03
Mar 24, 2013 03:23 AM
silvermonte1
Sep 16, 2011 12:14 PM
DavinGee
Jan 26, 2010 11:26 PM
