7th Gen ('06-'07): P0327
Old Sep 5, 2025 | 02:35 PM
MikeMcD1973's Avatar
Default P0327
I keep getting this code even after I changed the Sensor and the harness, is there something else I need to do?? What kind of issues would I be having with this code??
2007 Monte Carlo SS
Thanks in advance for any help!
Old Sep 7, 2025 | 12:39 AM
02MonteSS_D.E.'s Avatar
That code means the knock sensor is shorted to ground. I attached some testing steps to take as well as where it inputs to the PCM. If the resistance test is fine then I would check to make sure you don't have any chaffed wires from the knock sensor to the PCM causing the ground input to the PCM for the knock sensor.
YoungMonteLS
Apr 8, 2018 05:59 PM
owens91
13
Aug 17, 2015 05:11 AM
Big Red
Apr 5, 2014 12:45 PM
