P0171 in 3 miles
Old May 11, 2015 | 10:08 PM
  #151
plumbob's Avatar
Bad cat will definitely effect mileage if it's clogged, hope you bought an OEM one from Rock. I've heard aftermarket ones can be a problem, although I see a lot of members have this as a performance upgrade, but I get the impression from your previous posts you want to keep your Intimidator stock. I have no experience with high performance aftermarket stuff. Just going off what I've learned here.
Old May 12, 2015 | 05:37 AM
  #152
avendo's Avatar
I got a walker one,its should be close to stock..I checked it out and it was listed as a high flow also..
Old May 12, 2015 | 05:40 AM
  #153
avendo's Avatar
WALKER Part # 54627 {#54250} Walker EPA Ultra Direct Fit Converter (Rebate/Promotion Available!)
Fits Fed & Calif Emissions. Models; Not legal for sale in the state of California. Not legal for use on California emission vehicles in New York. Legal for use on Federal/EPA emission vehicles in New York.; Additional Parts Needed: 31605, 31578
Old May 12, 2015 | 07:36 PM
  #154
plumbob's Avatar
keep me posted on how it goes
Old May 13, 2015 | 05:25 AM
  #155
avendo's Avatar
50 buck gift card too...
Old May 14, 2015 | 08:49 AM
  #156
plumbob's Avatar
Bonus! Hope it all works out.
Old May 15, 2015 | 07:29 PM
  #157
bossross's Avatar
jumping in here, found a leak between my throttle body and intake mani
me and friend thinking, gasket or some silicone sealant? thoughts pros cons
Old May 15, 2015 | 09:24 PM
  #158
plumbob's Avatar
Hi Bossross. Personally, I would replace the gasket. It's only $3.21 at RockAuto.com and would take about an hour to replace. Depending on whether the original UIM has been replaced or not, you might want to consider going deeper and replace it with an improved Dorman. A design flaw in the OEM one allows hot EGR gas to melt the plastic port. The Dorman has a metal sleeve to protect against that. You could go one step further and replace the POS OEM plastic LIM gasket with a metal reinforced Felpro one while your at it. If you haven't changed these andyou own the car long enough, your gonna need to change them sooner or later. Here's the gasket though
Old May 16, 2015 | 09:17 AM
  #159
avendo's Avatar
Well I put another radio in the car and I get the same draw 2.2 Amps.. My original radio does the same thing what else could it be... If I pulled the amp plug out it drops to 1.75 amps
Old May 16, 2015 | 05:06 PM
  #160
plumbob's Avatar
I don't have any experience with the radios, but I do know if you don't use an original radio it will affect the BCM since the security system and all the RDS stuff interfaces with it. Probably a dumb question, but why is 2.2 amps a problem? The fuse is 15A. If it is a problem I would suggest starting a new thread to see if another member can help and keep this thread on the original P0171 track.
