P0171 in 3 miles
Old Apr 28, 2015 | 05:59 PM
  #131
plumbob's Avatar
Originally Posted by avendo
After I fixed the leak I saw the short-term fuel trim at zero then when it warmed up it went back up to 10.. Thought I had it fixed.
Did you monitor the fuel trim on a drive. I found that my FT was also high (16) after a long idle time, but went back down while and after I took it for a short drive.
Old Apr 28, 2015 | 06:53 PM
  #132
avendo's Avatar
it should be 0 if everything is right...even after running for a while.
Old Apr 28, 2015 | 07:07 PM
  #133
plumbob's Avatar
Then maybe I need to look for a problem in my MC. Lol. Thought she was running pretty good.
Old Apr 28, 2015 | 08:13 PM
  #134
bossross's Avatar
hey guys sorry to jump in, I have the same code
did the spray carb cleaner trick to find a leak
seemed like it was where throttle body met intake but on close inspection today I found an intake hole that seems to feed the iac motor
you can feel the air sucked in during idle, is this normal?
Old Apr 28, 2015 | 08:28 PM
  #135
plumbob's Avatar
Hey bossross, no apology necessary. Could you describe the location of this hole a little more precisely. I don't have any codes, but this could explain the 16% LTFT after long idle. You're talking about the UIM right?
Old Apr 29, 2015 | 06:17 AM
  #136
avendo's Avatar
20-25% will throw a code...10% ltft is fine,i was told 16 is to high,I should have MAF today..using a non GM one i was told it can be skewed,not reading correctly..hopefully this new gm one will help with my problem.
Old Apr 29, 2015 | 06:06 PM
  #137
bossross's Avatar
yes the uim. directly to the left of the iac
Old Apr 30, 2015 | 04:55 AM
  #138
avendo's Avatar
I did carb clean too but i didnt see that leak on the pcv cover.. Smoke found it.
Old Apr 30, 2015 | 12:14 PM
  #139
avendo's Avatar
MAF is in,will put it in after work,cross fingers and we will see if it does anything...
Old Apr 30, 2015 | 01:53 PM
  #140
avendo's Avatar
STFT 0% LTFT 0% ...maybe I have to take a ride but,right off the bat it read normal...so was the Cardone MAF just screwed up and sending more fuel to the car or ws it just reading wrong to the scanner?
