P0171 in 3 miles
Old Apr 30, 2015 | 08:52 PM
  #141
plumbob's Avatar
Has to have been a screwed up Cardone MAF 'cause the scanner is reading what info. the PCM see's. The PCM does what the MAF tells it to do. DO you think the PCV cover or the MAF was the culprit? I know it's been a long battle for you, but it really sounds like a success story. You must really feel some satisfaction in the results. I'll keep fingers crossed for you that it stays that way, but I feel pretty confident that it will. Glad I could help with this, it's been fun. I think I learned as much as you and now think maybe I need to change my MAF to get to 0% as well. Keep me posted.
Old Apr 30, 2015 | 09:10 PM
  #142
plumbob's Avatar
bossross, I haven't had a chance to look into the hole in the UIM, but I think your logic sounds right and it's normal. It's likely a breather hole for the IAC motor. It probably balances the "Pintle" during idle. if your problem sounds similar to avendo's I would read through this thread thoroughly and follow the lessons and techniques in troubleshooting. The smoke test for vacuum leak(s) and replacing the MAF with a genuine OEM GM one seems to have been the key.
Old May 1, 2015 | 05:16 AM
  #143
avendo's Avatar
I would not have believed it if I did not see it I want up-and-down that Car looking for a vacuum leak according to what the computer said now I have to try and take the cardone one back to AutoZone they don't warrantee except for giving you a new one watching that video on fuel trims is a big help too i'm glad I taught some other people things I grew up as a MacGyver fixing stuff and troubleshooting stuff all my life
Old May 8, 2015 | 08:53 PM
  #144
avendo's Avatar
well the p0420 code came back on today,booo.
Old May 8, 2015 | 09:22 PM
  #145
plumbob's Avatar
Darn, just when you think your done.......
Old May 9, 2015 | 06:38 AM
  #146
avendo's Avatar
got to check wave forms today on scanner.
Old May 9, 2015 | 08:54 AM
  #147
plumbob's Avatar
Keep me posted. Changed the MAF and PCV valve kit on mine after your experience and now at 0% STFT and 3% LTFT.
Old May 10, 2015 | 07:05 AM
  #148
avendo's Avatar
See i started something lol
Old May 10, 2015 | 08:50 AM
  #149
avendo's Avatar
Will a bad cat screw up my gas milege? Should i get a high flow cat?
Old May 10, 2015 | 08:39 PM
  #150
avendo's Avatar
bought cat from rockauto 166.00 hurts to do but..
