P0102 problems
Old Oct 3, 2008 | 10:56 AM
Jiggly's Avatar
Default P0102 problems
2002 Chevy Monte Carlo SS
V6 3800 series || 80K
Condition Mint
Yesterday the computer spit out a code P0102 Mass Air Flow sensor.
I removed the sensor and cleaned it with Mass Air Flow Sensor cleaner , and replaced the Air Filter with STP brand ,then waited about two hours and replaced all parts.
After ensuring the car was Fixed I drove to Auto Zone and had them Reset the Computer then drove home & parked the car.
This morning my son went to start the car and she was giving him a hard time starting, it would start hesitate then die out, I just spent the past two hours running the car in the garage and she will not spit out a code, but if I accelerate the engine the car will start to hesitate at 4000 RPM then die, the only way I can describe the hesitation is like this, if you have rented a car lately and accelerated the car over 75Mph it will govern the car down, that is the exact same sound this car is making when I try to accelerate.
Thanks in advance
Old Oct 3, 2008 | 12:07 PM
thewhitestcarlouknow's Avatar
Default RE: P0102 problems
i would just replace the mass air flow sensor. In my last car the smallest fingerprint would make it run horrible and it sounds like you are experiencing the same symptoms. It didnt give me a code either but once I replaced it in ran like a champ.
Old Oct 3, 2008 | 12:24 PM
Hi `Jiggly,
If you have cleaned your MAF good, and its still
acting `up it could be dirty injectors ? ? Maybe.
Have you ever run Sea Foam ?
Do you have your original Cat ?
Many members swear by Sea Foam.
Below are some links for you to check it out.
Good Luck from `Space
Sea Foam
Welcome to SeaFoam's website. SeaFoam is renowned as the finest, most multifaceted and safest petroleum product of our times.
www.seafoamsales.com/ - 11k - Similar pages
[*]products[*]gas engine applications[*]Buy Sea Foam products[*]Consumer information [/ul]
[*]Deep Creep[*]Contact Us[*]Trans Tune[*]Foam-About Us [/ul]
http://www.seafoamsales.com/
Sea Foam
(If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or ...
www.seafoamsales.com/motorTuneUpTechGas.htm - 19k - Similar pages
http://www.seafoamsales.com/motorTuneUpTechGas.htm
Sea Foam Usage Video
Sea Foam Usage Video. Details. Comments. More from user. Sea Foam Usage Video - 14 min - Feb 22, 2006 Sea Foam - www.dfadist.com. () Rate: ...
video.google.com/videoplay?docid=618729086572622... - 10k - Similar pages
Old Oct 3, 2008 | 12:28 PM
Jiggly's Avatar
About ten minutes she spit out the same code P0102 ,Ergg i had a feeling i was buying a new Mass Air Flow sensor , Auto Zone wants to charge about $140.00 for the sensor, is there another online car store that sells them for a cheaper price?
Old Oct 3, 2008 | 12:32 PM
Jiggly's Avatar
ORIGINAL: KidSpace
[align=center]Hi `Jiggly,[/align][align=center]If you have cleaned your MAF good, and its still [/align][align=center]acting `up it could be dirty injectors ? ? Maybe.[/align][align=center][/align][align=center]Have you ever run Sea Foam ?[/align][align=center]Do you have your original Cat ?[/align][align=center]Many members swear by Sea Foam.[/align][align=center]Below are some links for you to check it out.[/align][align=center]Good Luck from `Space[/align][align=center][/align][*]
[*]i have used sea foam in the past on different vehicles , GOOD stuff !! but in this case , this car doesn't even have one ounce of dirt in the throttle body, its in Mint condition and extremely well maintained by me.
Old Oct 3, 2008 | 12:47 PM
[align=center]Jiggly,[/align][align=center]You are Welcome, thanks for the re/post : )[/align][align=center][/align][align=center]AutoZone gave you a decent price @ $140[/align][align=center]
Delphi Mass Air Flow Sensor[/align]
SKU: W0133-1681892
Price: $166.26
List Price: $332.51
Saved: $166.25 (49%)
QTY:
Free Shipping
[align=center][/align][align=center][/align][align=center][/align][align=center]http://www.drivewire.com/products/ch...w-sensor/3557/[/align][align=center][/align][align=center]Lowest price I found was $130.[/align][align=center]Good Luck[/align][align=center]http://www.autopartswarehouse.com/se...02%20Chevrolet[/align]
sjanson13
Jun 9, 2013 05:32 AM
phatboy313
Apr 15, 2013 07:12 AM
JC Colon
Nov 26, 2012 09:52 AM
Endo
Jul 14, 2012 08:54 AM
bowtie8_3
Jul 20, 2009 07:24 PM
