Oxy Acetylene or Arc?
#31
RE: Oxy Acetylene or Arc?
ORIGINAL: SoCalSS
I don't know d*ck about welding, so which is better for a set of sway bar brackets? I was told that the welded ones are stronger than machined, but what kind of welding would be best for this application?
[sm=dontgetit.gif]
[sm=dontgetit.gif]
#32
ORIGINAL: mickey
first off please keep me out of this argument I have delt with him and his attitude before and dont want to wast my tiem doing it again.
but i will say one thing on this
04 you are just standing there sitring the pot all the time .
now there are times i have agreed with you and not with you
But the comment about a mans military carrer was one i defently do not agree with at all.
unless you have been in the service i would back off that one. it is not even close to being cool to start on that one in the borad or any other. you can have your own opion just dont put it out here for all to read on that subject.
i have said my peice
kicking soap box to the corner for the next time/
I swear either you and warpath are brothers or one in the same cause you both share the idiot gene.
The comment I made to your brother was in reference to his lack of common sense and overall stupidity, the field in which he was in is irrelevant cause my opinion would be the same in any field in which the stakes are so high and such an idiot was involved in any way, shape or form. So get your politically correct panties out of a bunch and get back to swingin' on his sack.
#33
So here I stand with my thumb up my butt..... MIG, TIG, FLUX CORE, welding clay????? better heat distribution? All sounds good to me. What I'm wondering... is which one is going to be stronger so that when I corner at 90 MPH my brackets won't pop off fly somewhere bad, like.....into my friggin gas tank or something.
#34
ORIGINAL: SoCalSS
Sounds like a few folks here know a lil something about welding and the consensus seems to be MIG.
#35
Well if you want the strongest than that would be TIG, but it's also more expensive and slighty harder to do. But in all honesty if the MIG is setup right(voltage and wire speed)it'll be plenty strong. Trust me, if it's good enough for rollcages it's good enough for a bracket.
I give answers and answers only when I'm tired.
#39
OK - my 2 cents. I am not a welder, but I work with welders every day, welding everything imaginable, from thin sheetmetal to extra heavy wall pipe to thick steel plate. The only welding to use on a vehicle is MIG or TIG, with MIG being the most common. It is also very easy to learn to do. Main reason to use it is it doesn't produce the widespread heat like stick rod and is a very strong weld. So, go with the MIG. If you plan on doing more welding, buy a MIG welder and just start welding with it. You'll be surprised how easy it is. If you need to cut metal on your car, go with a cutoff wheel and not the oxy/acetylene. If you use oxy/acetylene the cut will look like an allegator bit the metal off and be hell to repair.
I have bought SLP sway bars for my car 2 months ago but haven't even opened the box yet. I just haven't had time to get them installed. I hope they came with brackets and poly bushings!
Another comment - we are here to share our love and knowledge of MC's. Thats it. I too have trouble reading some of Mickey's posts, but I can tell you I've learned alot about MC's from him. We all have things we battle, some are just more visible than others. Hang in there Mickey and keep those posts coming. I value your opinion and knowledge. Sounds like some of 04's posts about Mickey are just joking with him, but if both parties don't enjoy the joke then drop it.
And good to hear from you TVW!
#40
ORIGINAL: rchurch
