Oxy Acetylene or Arc?
I don't know d*ck about welding, so which is better for a set of sway bar brackets? I was told that the welded ones are stronger than machined, but what kind of welding would be best for this application?
http://i231.photobucket.com/albums/e.../Iconfused.gif |
RE: Oxy Acetylene or Arc?
I'd suggest Arc welding as the heat affected zone is smaller and the welds are smoother.
ORIGINAL: 04MonteLS I'd suggest Arc welding as the heat affected zone is smaller and the welds are smoother. |
ORIGINAL: SoCalSS ORIGINAL: 04MonteLS I'd suggest Arc welding as the heat affected zone is smaller and the welds are smoother. If you want to be schooled on welding, I'd suggest doing a google search on the subject cause I don't have the knowledge or time to make you understand. http://i231.photobucket.com/albums/e...s/clueless.gif |
ORIGINAL: 04MonteLS ORIGINAL: SoCalSS ORIGINAL: 04MonteLS I'd suggest Arc welding as the heat affected zone is smaller and the welds are smoother. If you want to be schooled on welding, I'd suggest doing a google search on the subject cause I don't have the knowledge or time to make you understand. http://i231.photobucket.com/albums/e...s/clueless.gif LMAO! ahha hahahhaa |
I'm just as green behind the ears as you when it comes to welding. |
welding 101
If yo have a arc welder then go get teh mig attachment for it then make sre it stays where you put it lso use some heat sink clay and pack the area so that yo suck that heat out of there you dont want to destroy the metal harness in that area by getting it to hot and taking the temper out of it Now in a pinch you could use your arc welder just pack it with the clay and weld fast. but all three will hold them in place oxy/acetylene is a slower weld soit makes more heat and cuses more warpage tot eh metal and also can take the temper out of the metal faster Arc welding is a faster weld so you can add th heat to wqeld it in and get in and out fast to allow les damage from the heat MIG puts the heat right where ya need it and will weld and penitrate he metal faster and better then any of the other two will good luck |
ORIGINAL: mickey welding 101 If yo have a arc welder then go get teh mig attachment for it then make sre it stays where you put it lso use some heat sink clay and pack the area so that yo suck that heat out of there you dont want to destroy the metal harness in that area by getting it to hot and taking the temper out of it Now in a pinch you could use your arc welder just pack it with the clay and weld fast. but all three will hold them in place oxy/acetylene is a slower weld soit makes more heat and cuses more warpage tot eh metal and also can take the temper out of the metal faster Arc welding is a faster weld so you can add th heat to wqeld it in and get in and out fast to allow les damage from the heat MIG puts the heat right where ya need it and will weld and penitrate he metal faster and better then any of the other two will good luck |
please forgive me for not being perfect like your self.
some of us have a reason for wha tthey do or how they do it. but i guess you cant seem to over look that. or can you? |
ORIGINAL: mickey please forgive me for not being perfect like your self. some of us have a reason for wha tthey do or how they do it. but i guess you cant seem to over look that. or can you? |
