Overheating!
Old Nov 10, 2010 | 11:40 AM
major1's Avatar
Default Overheating!
I have a 2005 Ls. I'm having a problem with my fans. They do not come on. I recently changed the sensors and relays. They started back working, but now they dont again. Can anyone tell me what the problem might be?
I was thinking of straight wiring it, where my fans stay on when the car is started.
Old Nov 10, 2010 | 11:52 AM
Hi Major, sorry to read about your problem.
Below is a article on overheating.
Check back on your thread to see what our expert tech member's post on your problem.
I hope the below link helps in some way...Good Luck
http://www.troubleshooters.com/toverheat.htm
Below is another link on overheating...
http://www.aa1car.com/library/overheat.htm
Old Nov 10, 2010 | 02:10 PM
If possible, I would recommend connecting with a car scanner that can tell you what the computer is reading for the temperature. Inspect for a short in the wiring as well (sensor and fan wiring).
Old Nov 11, 2010 | 10:19 AM
major1's Avatar
OK, how do i get a scanner?
Old Nov 11, 2010 | 10:20 AM
major1's Avatar
thanks!
Old Nov 14, 2010 | 10:57 PM
Sorry, I've been out of town. As far as getting a scanner, I don't think that's a loan a tool item. You'll pretty much need to find someone you know who has access to one. Some of the parts stores sell them (but I don't know if they can get you the sensor reads).
On my '94 Grand Am, I've used an old OTC Scanner I have access to (unfortunately, I don't have access to a newer scanner for the Monte at this time).
Old Nov 15, 2010 | 12:40 AM
Enzo354's Avatar
STILL SLOW
Do the fans stay on ever after the car shuts off. Its simple and seems unrelated, but try changing your thermostat, it might fix it.
mirramir
Sep 11, 2008 10:22 PM
76MonteMan
Jun 21, 2008 10:14 PM
1WX27
Apr 4, 2008 04:42 PM
afterburn
Feb 8, 2008 07:49 PM
zx3adamania
Jan 12, 2008 06:36 PM
