Overheating!
I have a 2005 Ls. I'm having a problem with my fans. They do not come on. I recently changed the sensors and relays. They started back working, but now they dont again. Can anyone tell me what the problem might be?
I was thinking of straight wiring it, where my fans stay on when the car is started.
Hi Major, sorry to read about your problem.
Below is a article on overheating.
Check back on your thread to see what our expert tech member's post on your problem.
I hope the below link helps in some way...Good Luck
http://www.troubleshooters.com/toverheat.htm
Below is another link on overheating...
http://www.aa1car.com/library/overheat.htm
If possible, I would recommend connecting with a car scanner that can tell you what the computer is reading for the temperature. Inspect for a short in the wiring as well (sensor and fan wiring).
OK, how do i get a scanner?
Sorry, I've been out of town. As far as getting a scanner, I don't think that's a loan a tool item. You'll pretty much need to find someone you know who has access to one. Some of the parts stores sell them (but I don't know if they can get you the sensor reads).
On my '94 Grand Am, I've used an old OTC Scanner I have access to (unfortunately, I don't have access to a newer scanner for the Monte at this time).
1WX27
Apr 4, 2008 04:42 PM
