6th Gen ('00-'05): Only one turn signal.
Old Sep 3, 2014 | 04:21 PM
WImonteman's Avatar
Default Only one turn signal.
I have a 2005 monte that only one signal is working, ive replaced the hazard switch and fuse, the signal fuse in drivers side panel, and multifunction switch. Is there by chance a separate fuse for the other sides signal? Otherwise what else could I try?
Old Sep 4, 2014 | 11:20 AM
vikesfan's Avatar
wiggle the wire harness up by the headlight and see what happens.
i have an intermittent short to ground on my harness i havent fixed yet. the signal will blink fast or not at all, then i go wiggle the harness and it works fine for a week or two.
Old Sep 4, 2014 | 08:20 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
A burned out bulb on one side front or rear will also cause it not to blink the side that has a bad bulb or blink rapidly.
Old Sep 5, 2014 | 09:19 AM
I would also check the body and chassis grounds.
trey0503
Apr 27, 2018 11:39 AM
Raider
Jun 18, 2014 11:15 PM
djizzle
Jan 19, 2007 01:05 PM
Nortybignort
Jul 25, 2006 10:35 PM
Lee55
Jun 9, 2006 09:20 AM
