Only driver side highbeam is out
Old May 2, 2025 | 05:09 PM
Korizon's Avatar
Default Only driver side highbeam is out
Hello there this is my first post on this forum so i apologize if I'm doing this wrong but,
My car is a 2003 Chevrolet Monte Carlo SS 3.8 V6. I just got new OEM headlights for my car because the everything on the drivers side was out. Now only my passenger side high beams turn on and i can't seem to figure out what is causing this. I've replaced both fuses for both headlights and tried changing the bulb for another one that i know works but still nothing.
Old May 4, 2025 | 02:19 PM
And it started after changing the headlights? If so, that is really odd. Since you swapped bulbs and the problem persists, my guess is either a damaged wire or the multi-function switch (aka the turn signal stalk). To figure it out, you will probably need some wiring diagrams and start tracing things out.
Old May 25, 2025 | 10:51 AM
Henderson21's Avatar
Try checking the spring contacts at the base of the socket. They might not be making contact with the bulb.
TiredPerson
MCF Website Problems & Issues
Aug 23, 2023 04:37 AM
wetherb67
Feb 9, 2019 09:14 AM
Myshell Ray
Mar 22, 2017 12:51 PM
iamjoshz
Apr 2, 2013 10:09 PM
MJClemm
Jan 27, 2011 01:27 PM
