Opinion Needed: Oil Pan Gasket with cradle Removed
Old Jan 9, 2015 | 09:59 PM
outlaws2014's Avatar
Default Oil Pan Gasket with cradle Removed
2002 Monte Carlo SS. The cradle is dropped to replace the transmission at the dealer. How long/ how many hours should it take them to do the oil pan gasket with the cradle removed and the transmission removed?
Thanks,
Bill
Old Jan 10, 2015 | 11:08 AM
I would think with the cradle and trans out of the way, an oil pan gasket should not take long at all.
Also, if the cradle is off, consider changing the lower engine and trans mounts.
Old Jan 10, 2015 | 11:27 AM
Default Trans and Engine mounts
I am considering as you suggest. It is a 2002 and is 13 years old but only has 50k miles.
Thank you for the response.
Bill
24_48Fan
Apr 2, 2010 07:19 PM
montechick
Mar 13, 2010 09:54 AM
Chevycarlo97
May 25, 2009 04:30 PM
shanefer
Apr 21, 2009 04:12 PM
koreancore
Jan 14, 2009 04:59 PM
