oil burning
Old Jun 13, 2012 | 10:17 PM
1988mcss's Avatar
Default oil burning
I have an 88 ss monte carlo with a 350 mild cam and port and polished heads. I drove the car to florida and back and it burned 14 quarts of oil in that 2200 mile jouney but no visable leaks anywhere and no smoke out the exhaust. When you step on the gas it breaks apart when you maintain speed the rpms jump it back fires and hesitates and idles rough. What could be the problem? I pulled the plugs and they are fouled out some burned the elctrode white and others had oil and carbon build up on them.
Old Jun 13, 2012 | 10:47 PM
14 qrts of oil in 2200 miles......
Old Jun 13, 2012 | 11:32 PM
Enzo354's Avatar
STILL SLOW
I had that same issue, I think you just have a bad front crank seal. Mine was puking oil on the highway where I couldn't see it. I lost 4 quarts one night. I stuck on some valve cover breathers and it stopped building so much crank pressure. Never lost another drop.
Old Jun 14, 2012 | 05:07 AM
1988mcss's Avatar
Default oil burning
Yea but there is no oil on the ground at all. Its just burning it.
Old Jun 14, 2012 | 08:52 AM
Budsjlm's Avatar
have you looked on the botom side of the car, just becuase it isn't leaving any on the ground doesn't mean it's not leaking, ig the underside of the car is dirty could just be sticking to that and you would never know,
thats a rate of a quart every 157mile yike!
could be a number of things, everything from a bad pvc (i dought), worn rings, gummed up rings, bad valve guides, bad valve seals,
Do a compression test, try to get your hands on a leak down tester and do a leak down test aswell
Old Jun 14, 2012 | 05:03 PM
1988mcss's Avatar
Yea there is no oil on the underside of the car at all its just burning it. I took off the valve covers and everything looks good there. Someone told me to take off the carb and check the inside of the intake manifold I found oil there not a lot but a good amount could the intake gaskett be bad ant it sucking it up through the intake?
Old Jun 14, 2012 | 05:23 PM
Enzo354's Avatar
STILL SLOW
Look really close behind the balancer, if it's leaking fast enough it will blow off with the wind and be barely noticable, and of course you won't see it on the ground. It's probably not building up pressure until you are at a higher speed like 60.
Old Jun 15, 2012 | 03:48 PM
1988mcss's Avatar
I checked the front crank seal and no issues there. I'm just gunna have it checked out by a local engine builder in the morning and see what he says but thanks for the suggestions and all the help.
Bego
Nov 10, 2009 10:41 AM
freeguy555
Apr 6, 2008 07:17 PM
freeguy555
Apr 6, 2008 07:02 PM
jd5419
Nov 27, 2006 12:09 AM
mymonte
Nov 22, 2006 10:50 PM
