o2 sensor help!
There are 2 oxygen sensors on your car . One is located on the backside of the engine where the exhaust leaves the engine.(upstream) and the other is located next to the catalystic convertor in the exhaust pipe(down stream). Good luck .
thanks! I hope that's the right one? the guy that looked at it said it's the one before the cadilac converter
Its difficult to even see unless you rock the engine forward. You CAN see it if you know what youre looking for but still can be hard to find.
5th Gen ('95-'99): o2 sensor
Leprechaun93
10-08-2013 04:27 PM
Ace25
01-10-2013 11:32 AM
