o2 sensor help!
Old Oct 26, 2018 | 05:58 PM
hfsitsshay's Avatar
Default o2 sensor help!
I cannot find where my upstream o2 sensor is! I've looked everywhere and I've even looked online all over..Im trying to fix it myself because I don't have money to get it fixed..I have an 04 with a 3.8 engine
Old Oct 27, 2018 | 06:15 AM
Jeffs02rwdSS's Avatar
There are 2 oxygen sensors on your car . One is located on the backside of the engine where the exhaust leaves the engine.(upstream) and the other is located next to the catalystic convertor in the exhaust pipe(down stream). Good luck .
Old Oct 27, 2018 | 10:27 AM
hfsitsshay's Avatar
thanks! I hope that's the right one? the guy that looked at it said it's the one before the cadilac converter
Old Oct 28, 2018 | 07:51 AM
The one nearest to the cat is the downstream. The upstream is basically IN the rear exhaust manifold. Certain on this.
Its difficult to even see unless you rock the engine forward. You CAN see it if you know what youre looking for but still can be hard to find.
Old Oct 28, 2018 | 12:15 PM
This drawing is a nice shot of it (looking straight at the back of the engine from the firewe all side).
Old Oct 28, 2018 | 03:44 PM
I've never had a problem seeing it. Granted, I don't have the secondary AIR injection system (which is primarily for California emissions). That may make it a bit trickier lol.
Twitchy
Mar 18, 2017 11:00 PM
Leprechaun93
Oct 8, 2013 04:27 PM
guhnny
Aug 22, 2013 05:55 PM
Ace25
Jan 10, 2013 11:32 AM
goingforgold
Nov 30, 2010 11:17 AM
