not starting lately
Old Jul 4, 2011 | 01:53 AM
BlarneyStone13's Avatar
Default not starting lately
2003 ls - When i turn my key the engine starts to turn, but the battery dies before it starts. Battery is good, drawing 12 volts when running, alternator draws 14 volts, any ideas? With a charger hooked up it starts right up. I THINK i checked all the grounds. Cleaned all battery connections. Is this a starter issue? I have also been told possibly fuel pump?
Old Jul 4, 2011 | 03:37 AM
nitehawkjcb's Avatar
If the lights cut out, it's a charging issue or a loose ground. Make sure the terminals are tight. If that isn't the case, you could have a bad battery. I had mine tested a while back, passed the test, 12 volts, all that. Lights would cut out, but would come back on if I turned the key off and on. Car wouldn't start though. Replaced the battery, started right up.
Old Jul 4, 2011 | 09:03 AM
nichols2k's Avatar
x2 ^^nitehawkjcb said... in one week, I had my Fusion and Expedition batteries die. Working in the morning... dead that afternoon... The Fusion was similar to yours where everything seemed ok, but when I cranked it over it sounded worse and worse.. changed battery and everything was good.
Old Jul 9, 2011 | 11:44 AM
UPDATE- Turned out to be a bad internal terminal in the battery. I thought the battery was newer, turns out it was the original from 2002. Felt kinda dumb.
Old Jul 9, 2011 | 01:07 PM
Glad you got it figured out
blackmonte781
Aug 22, 2011 10:18 PM
ChibiBlackSheep
Jun 16, 2011 11:45 AM
knightfan26917
Mar 27, 2009 10:29 AM
dustybird3
Aug 21, 2008 11:51 PM
04MonteLS
Jul 15, 2005 12:05 PM
