NOT happy!
Old May 28, 2010 | 12:52 AM
Pure2sin's Avatar
Default NOT happy!
I am going to be putting my suspension on this weekend possibly, BUT! I was fooling around with my lights, installed new bulbs and ballasts and now my Airbag light is staying on after I start my car. The other weird thing is when I go to turn my A/C on during the day when the DRLs are on the little light on the button does not come on. At night it works fine. I am trying to avoid bringing it to a shop but I can't figure it out. Dealership is even worse I feel like I need to bring a cross, steak and garlic with me.
Old May 28, 2010 | 10:36 AM
Hi `Josh, Sorry to read about your problem.
Check out the below link...Hope it helps or gives you some idea of your prob....Good Luck 4-Sure
https://montecarloforum.com/forum/monte-carlo-repair-help-8/service-airbag-light-arg-2444/
Old May 28, 2010 | 02:34 PM
Pure2sin's Avatar
Thanks KidSpace. I looked an went through all the other posts to see if I could find a solution but nothing is working. I guess I am going to have to bring to to the dealership or call around to see who has a Airbag module scanner/re-programmer because I can't think of anything else it could be.
Old May 28, 2010 | 10:16 PM
lucian*91's Avatar
did you move wires to your impact sensor in the front of your car while you were changing you lights and stuff? maybe make them loose. any signal interruption in the SRS system will trigger that light. and thats the clossest module i can thing of as far as wiring
Old May 28, 2010 | 11:35 PM
Pure2sin's Avatar
I wonder if I did that when I put the new fog light bulb in?! I guess I will have to check on that. Thanks for the suggestion.
Old May 28, 2010 | 11:59 PM
lucian*91's Avatar
no problem. only here to help
The_Maniac
Dec 25, 2014 10:04 AM
JC Colon
13
Sep 25, 2014 09:53 AM
wht02monte
Apr 18, 2010 06:19 PM
MAMONTE
Aug 7, 2009 01:07 AM
BackNBlack
Oct 30, 2008 02:45 PM
