No turn, brake, or emergency flashers.
Old Nov 26, 2013 | 06:08 PM
johns811's Avatar
Default No turn, brake, or emergency flashers.
Hi new here.
Have 1999 z34. The brake lines rusted through so I had it towed to the shop and replaced. Wife driving home, no turn signals or brake lights (except the little one in the window). Checked the emergency flashes and the little switch appears to be cracked. My guess is the tow driver broke it. Would this kill the entire system. If I drop the switch back in place I can can hear it click on and off. I read and posted on another thread that the hazzard switch would cause all of this. I hate to blame the shop for breaking it but it sure seems like they must have. Everything was fine before we had it towed. How hard is it to replace that hazzard switch? All help appreciated.
Old Nov 26, 2013 | 06:13 PM
l67ss's Avatar
Its not tooo bad, gotta pull steering wheel, airbag coil, ignition lock ring, and lower cover on dash
Old Nov 26, 2013 | 06:23 PM
johns811's Avatar
Is there step by step directions anywhere on how to do this?
Old Nov 26, 2013 | 06:36 PM
l67ss's Avatar
I looked in a chilton manuel when i did mine
Old Nov 26, 2013 | 06:46 PM
johns811's Avatar
Did you have the same problem with the hazzard switch or the turn signal switch. Everything was working perfectly before it was towed to the shop. Thanks!
Old Nov 28, 2013 | 05:32 AM
johns811's Avatar
So I toggled the emergency flasher switch about 12 times and the turn signals and brake lights started working again.
Old Nov 28, 2013 | 04:36 PM
l67ss's Avatar
Mine just took a dump from usage lol
monteriderLS
Nov 30, 2012 02:55 PM
RickCoMatic
Sep 8, 2011 09:59 PM
jmichael67
Feb 25, 2011 01:55 PM
paintballerr78
Dec 8, 2009 04:38 PM
04MonteLS
Oct 14, 2008 10:39 PM
