Opinion Needed: No crank/start in morning 2005 LS
Old Jul 14, 2018 | 07:36 AM
Josh Brown's Avatar
Default No crank/start in morning 2005 LS
Hi I'm new to this forum and I really need help I just got a 2005 monte carlo ls and it was working fine up to 4 days ago I got the car in florida and drove it back home to colorado it was starting fine and the last 4 days it won't crank or start in the morning but when I get off of work it starts right up I think it might be the security system but I can't deactivate it because it doesn't have the stock stereo in or is it the starter any ideas on what I can do thank you
Old Jul 16, 2018 | 07:47 PM
EvanLauer's Avatar
What kind of motor do you have in it?
Old Jul 18, 2018 | 06:36 PM
Josh Brown's Avatar
3.4 v6
Old Jul 18, 2018 | 09:52 PM
EvanLauer's Avatar
Is the security light flashing 3 times? Or is it just solid?
If it is flashing 3 times, you're probably dealing with the ignition switch failure. Not too hard to fix, but it's not cheap. Just take the dash off, remove 2 bolts, pull the ignition cylinder out, unplug it. Then you just plug the new one in, reassemble it all, and do the security relearn.
Old Jul 20, 2018 | 09:30 PM
Josh Brown's Avatar
I will take a look this weekend and see and I'll get back with you
Old Jul 23, 2018 | 12:31 AM
Josh Brown's Avatar
So I looked at it the security light is solid and I tried starting it at nigh without it running all day and it's doing the same thing
Old Jul 23, 2018 | 09:43 AM
EvanLauer's Avatar
I'd say take a look at the starter then.
Old Jul 23, 2018 | 01:39 PM
Josh Brown's Avatar
I will and I am going to check the relay switches to see if the contacts on the pins are making a full connection
Nov 12, 2019 12:08 AM
xpage
Oct 15, 2019 11:52 PM
N_robertson
Oct 9, 2017 09:04 PM
avendo
Jul 16, 2015 01:53 PM
ErMiller79
Oct 19, 2012 05:17 PM
