never seen this happen before
UPDATE: now, the security light is on and stays on while the car is running. It starts fine now (almost as if before it was just a hiccup) im going to try my spare key when the girlfriend and I go out.
Also, is it okay to use electronic parts cleaner in the lock cylinder? I have read that it might get dirt in it and cause the same problem and if I clean it, that could possibly fix my problem.
Either way, im looking at bypassing my passkey if anyone knows a way. I have seen other forums where people talk of how to do it with resistors or a bypass module, but I trust my mcf family more than anyone else when it comes to my monte.
My Passlock has been on the fritz for the past 2 years. All my research comes to the same conclusion as others have already stated: install a bypass, either store-bought or homemade. I plan to buy one myself, just haven't gotten around to it yet.
I did a write up awhile ago. It was easy and didn't cost me anything... Best thing I ever did, no more passlock issues.
https://montecarloforum.com/forum/sh...ad.php?t=17611
Sorry, I just want to cover all grounds before going into this... there will be no turning back once I do. I usually build my own kits and am looking at professional ones just because I don't want my car messing up at all.
Alright, I went to best buy. They told me that since I have the resistor in my key, they'd cut the wire going into the switch and put a resistor in there... that's the only option they gave me, so it looks like im doing the" like a big dog" mod. Unless I find that nocturx's meathod works better.
guy at chevy told me that I most likely wouldn't have a problem, but he can't guarantee anything.
Also, the guy at the radio shop told me he can't warrenty or gurantee anything with the resistor mod either.
I just don't want to go into all this trouble to save a few bucks and not rid myself completely of this passkey headache.
And from what the chevy dealer wants to charge, I would rather get rid of the system for that cost.
You could turn back if needed. It doesn't have to be permanent. Just cut out the resistor and reconnect the wire. Not sure why you would want to reactive the passlock though.
Not reactivate, just not screw up more. Passkey is the resistor in the key that contacts something inside the ignition switch. My ignition is in the steering column, not the dashboard.
I know you can pull the driver kick panel and access the wiring.
I don't think anything is needing to be done right now... I just have the annoying light on in the dash. I would try the resistor mod, but the car runs. I just want to be sure passlock/key/vats is permenantly gone. Is the resistor for sure going to do that?
Why there was never a recall for the passlock system is beyond me. Well I know why, because gm put it in every vehicle they made and it would have killed them to do a recall but if you google "carcomplaints passlock" you'll see pages and pages of complaints from people about the passlock system. GM should be ashamed.
I only have a bachelors in electronic engineering and am no where near the geniuses GM hires to design their electrical systems but even I know resistances can fluctuate in a circuit, the tin pins oxidize, temperature and humidity can affect resistance for example. Resistance based security systems are not uncommon, they just didn't allow enough of a variance in resistance in their programming I would guess.
Scooby doo
04-13-2015 10:09 PM
6th Gen ('00-'05): Electrical -Please Help- PCM/BCM Codes I've never seen before
Henderson21
07-26-2014 03:37 PM
6th Gen ('00-'05): Have never seen this before
MONTE CARLOS
21
06-22-2012 11:41 AM
monte carlo 3831
07-02-2009 11:10 PM
