need help please
Need to replace my heater assembly and the metal cables behind it ,in my 84 monte. What other chevy cars heater assembleys are interchangable ? Can heater controls from a newer monte be made to work ? thank you in advance.
I have this but I would have to check under the dash for cables but I don't think they are there anymore
I will have to check when I get home
Thats exactly what i was talking about. There are 3 cables that attach to the back... i think they open vents.( not sure though ) and the idiot i bought the car from pulled the stereo and cut everything, so i was wondering what other GM's would have the same controls ? And since i have to replace the cables and wires i was curious if i could put newer controls from a newer car in as well ?
these are the cables im looking for and here are other newer controls i was wondering if they would work ( something along this line ) and what would be involved to upgrade to newer controls ?
I don't know if newer controls will work or not. Other vehicles with the same set up would be regal, cutlass, grand national, and el camino of around the same year.
I ended up not getting out to the car last night when there was enough light. I will get up under my dash tonight and see what is stuffed up in there with all the wires.
You could browse google for info on upgrading to newer controls.
The Newer ones are electronic and you might be able to adapt them?????? But it will take some doing.
chevyONmine
Aug 1, 2023 07:33 AM
7th Gen ('06-'07): Need some help with water leaking on passenger side of 7th Gen Monte. Please help!
MCSS06
May 29, 2015 08:04 AM
blackmonte781
Oct 3, 2011 01:38 PM
rmase182ls
Feb 28, 2011 03:57 PM
