Need help with electrical problem....
Old Oct 25, 2010 | 02:12 PM
hctr154's Avatar
Default Need help with electrical problem....
Hello,
I have a 2004 Monte Carlo LS, with 61,000 trouble-free miles, until now. Yesterday I noticed some strange, electrical popping noises coming through my speakers. Then, my gauges seem to randomly quit working and come back on. The seat belt and air bag light would flash off and on for a few seconds as well. Message center display would show, security, change oil, etc...
Thinking my alternator was going bad, I pulled it off and took it to a reputable auto electric repair shop. According to them, it is fine. I put the alternator back on, and started it up. Within a few minutes, the same thing started happening.
I'm at a loss. Has anybody had a similar problem or have any ideas??
Oh, I do NOT have any aftermarket stereo equipment or other electrical accessories.
Thanks.
Old Oct 25, 2010 | 02:50 PM
montejass's Avatar
Check your ground wire and battery cables in general. I had something similar happen to me and it was the battery cable.
Old Oct 25, 2010 | 06:54 PM
Wilco's Avatar
X2 on the ground cable. Same problem here! Try changing the ground cable to a heavier gauge and cleaning the metal on which it's screwed on. Also, check to make sure you other grounds around the engine bay are secured.
Old Oct 26, 2010 | 12:23 AM
Milhouse's Avatar
A friend of mine had a similar problem, turned out to be a bad ground wire. I think the guys above are on to something
MontErie2012
Jan 8, 2013 12:21 PM
Big-O
Jun 4, 2012 03:00 PM
Steven73
Oct 30, 2011 06:40 PM
plokm24
Mar 8, 2011 05:01 PM
plokm24
Mar 7, 2011 07:28 PM
