Please Help!! Electrical Problem
Old Mar 8, 2011 | 04:59 PM
plokm24's Avatar
Default Please Help!! Electrical Problem
I have a 2000 mc ss my battery has been draining overnight. Has been pulling the radio/amp fuse lately and the battery has not dying. Use a multimeter and read out a 1.50 amp drainage with the radio/amp fuse in. When i pull it out i get a 0.5/0.6 amp drainage. i was told that it would be the factory amp, but just recently replaced it with another factory amp. Do anyone know of the radio causing this problem?
Old Mar 8, 2011 | 05:01 PM
plokm24's Avatar
I have been doing some troubleshooting myself. So here is what i have done,because i know its coming from either the radio or amp, i would leave the fuse in alone with the amp and do a meter test and it would come out around 0.5/0.6 amps draw. When i reverse it with the radio in and fuse i get around 1.5 amps draw. With both and the fuse i get about 1.7 amp draw. And that 1.7 amp draw i am not sure if that is a normal draw because of the radio memory and the security o the radio and the other functions of the radio.
Henderson21
Jul 26, 2014 03:37 PM
lipperking
Sep 11, 2012 03:48 PM
383strokinit
Jan 29, 2012 07:56 PM
MontePrime
Aug 1, 2011 08:47 PM
plokm24
Mar 7, 2011 07:28 PM
