Need help with 88 monte running weird
Old Apr 22, 2014 | 08:08 PM
Nismosr20's Avatar
There actually is a leak, I believe it's gas but doesn't smell like it. It's right under the middle of the driver door. And I was gonna drain the tank, but I had started running the gas through. The carb is fine, but the accelerator pump leaked, so that was fixed. And the is an electrical issue. None of the gauges work, the a/c is wired backwards and there's no horn. But to your theory of an animal in the car, there is a ton of snake skin if the a/c vents.
Old Apr 22, 2014 | 08:19 PM
Nismosr20's Avatar
I was
Old Apr 24, 2014 | 11:47 AM
slowguy's Avatar
I had a gm 350 that was doing that, the distributor gear sheared the roll pin, but it did not break clean, it had a sharp piece that cut a groove on the shaft. Every once in a while it would shut off. After a few cranks the gear shear pin would pop back in the hole and it would run fine. I did not troubleshoot it until it blew the muffler off the car.
anthony_8606
Mar 18, 2021 02:29 PM
owens91
Dec 13, 2012 11:55 PM
Zmonte34
Dec 2, 2011 05:19 PM
TheCountOfMonteCristo1998
Feb 22, 2011 06:46 PM
mj_duffy1989
Aug 17, 2007 02:28 PM
