need an excorcist, BCM, have major short, or?
Old Apr 18, 2011 | 06:07 PM
DerEin's Avatar
A 2 or 4 ohm load on an amp is typical in car audio. I don't know why you would think an amp only accepting those would mean you couldn't run an aftermarket head unit into it? A lot of the guys you hear who have massive subwoofers in their cars run on 2 ohms. The 2 ohms just give you a higher power rating which gives you a larger "thump" but you lose some sound quality. Thus 4 ohms = less power rating bet better sound. Most all home stereo systems run on 8 ohms, thus the need for a self-powered auxiliary subwoofer.
Also those adapter kits for steering wheel controls are not a 100% thing. When I was still in college I worked for a Circuit City for a while and the car audio techs were constantly bad mouthing them, just to give you a heads up. If I recall they gave them a roughly 75-80% chance of success.
Old Apr 19, 2011 | 08:28 AM
BIGAL131's Avatar
Ok Dusty....here is the info for one of the many radio shops that have unlocked GM radios for your Monte. You can call them toll free at 1-866-380-0529..the shop is called S.P.L. Electronic.....their web site is as follows oem-auto-accesory.com/factory_gm_radios.html. I'm sure you can call them and talk to a tech about replacing your faulty radio with one of theirs which wont be coded and it will be plug and play...hope this helps you out.
Old Apr 19, 2011 | 08:41 AM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
THANK YOU! I'll definitely check it out!
Old Apr 19, 2011 | 07:48 PM
BIGAL131's Avatar
I'm sorry dusty....the link i gave you isnt correct......its as follows: www.oem-auto-accessory.com that is their web site or just call them... Your Welcome!
Old Apr 19, 2011 | 09:39 PM
dustybird3's Avatar
Photobucket
No problem, I figured out the typo I emailed them and they said they do have one, I just have to recover from the $600+ I just spent on it the last two weeks. Hope they still have one in a couple of weeks. Thanks again!
chuckt
Mar 28, 2015 01:35 PM
NYGiantsfan
Jun 5, 2012 07:12 AM
kc2kth
Mar 31, 2012 11:16 PM
ianbmxr
Jan 26, 2010 08:37 AM
oldnumber7
Feb 4, 2008 04:17 PM
